What is relation between CRS and GSR?
wfqk
Level 5
Level 5
Hi What is relation between CRS and GSR? Anyone can explain it briefly? Thank you so much.
both CRS (Carrier Routing System) and GSR (Gigabit Switch Routers) are large, high end platforms used mainly by ISPs and large enterprises. GSR (12000) is as far as I recall capable of 10G, while the CSR goes beyond 100G.
Cisco Carrier Routing System (CSR)
http://www.cisco.com/c/en/us/products/routers/carrier-routing-system/index.html
Cisco 12000 Series Routers (GSR)
http://www.cisco.com/c/en/us/products/routers/12000-series-routers/index.html
Thank you so much for your reply.
In our MPLS environment, ASR9K is used as CE, which is connected to client router.
The below is part of output of “show version” on the PE. The PE router should be CRS based on the below. Do you think what kind of CRS the router is? CRS12000, or other name?
show ver
Cisco IOS XR Software, Version 5.1.4[Default]
Copyright (c) 2015 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 2.10(20140717:214615) [CRS ROMMON],
System image file is "disk0:hfr-os-mbi-5.1.4.CSCun78466-1.0.0/0x100008/mbihfr-rp-x86e.vm"
cisco CRS-16/S (Intel 686 F6M14S4) processor with 12582912K bytes of memory.
Intel 686 F6M14S4 processor at 2135Mhz, Revision 2.174
Cisco CRS Series 16 Slots Line Card Chassis
2 Management Ethernet
83 DWDM controller(s)
80 WANPHY controller(s)
96 TenGigE
48 GigabitEthernet
3 HundredGigE
1019k bytes of non-volatile configuration memory.
14712M bytes of hard disk.
10449904k bytes of disk0: (Sector size 512 bytes).
10449904k bytes of disk1: (Sector size 512 bytes).
Look like a 16 slot chassis:
http://www.cisco.com/c/en/us/td/docs/iosxr/crs/hardware-install/crs-1/16-slot/system-description/b-crs-crs1-16-slot-line-card-chassis-system-description/b-crs-crs1-16-slot-line-card-chassis-system-description_chapter_01.html
