What is route-map track-primary-if
ktravis02
Hi, I was reviewing the running config for a new router, and found an entry I don't understand what it does nor how it got there. I can only think that the http server somehow put it in when I was using that. Can anyone explain what this does, and why it might suddenly appear in the config?
route-map track-primary-if permit 1
match ip address 197
set interface GigabitEthernet0/0/1
Ken
Hello
yes the route-map is ghost configuration along with
ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/1 overload
Its not servicing anything so it can be removed along with the above if you wanted
to
Kind Regards
Paul
7 Replies 7
Hello
that is just a route-map named
track-primary-if - It has no other meaning
as for the route-map it is matching on a access-list 197  and possibly performing policy based routing or NAT
To confirm that you can run
show policy-map
Kind Regards
Paul
Hi Paul,
dsl-router#show policy-map
dsl-router#
dsl-router#show ip policy
Interface Route map
dsl-router#
And I have no access-list 197
Ken
Helllo
So then it looks like a ghost configuration
if you post the running configuration then we can confirm that
Kind Regards
Paul
Ok
If you happen to see any miss-configurations or problems, please let me know.
Hello
to
Kind Regards
Paul
Ok, thanks! Do you think that was something the http server put in?
