what is the best solution for this requirement ???
mohammed hashim
hi
if the head office in US and there are 4 different branches in other countries ! like china and middle east ,,, etc
the database servers are in the head office and the braches should be able to connect to the server with 1 Gbps,
and also the branches should be able to communicate with each other (for example to access shared resources)
what is the best technology to run this network ?
thanks,
Dragan Ilic
Level 4
Level 4
DMVPN or full mesh site-to-site VPN...offcourse if you want to have secured network environment...
HTH,
Dragan
HTH,
Dragan
sounds DMVPN put its self in everything nowadays,
I think that is why they have put it in CCIE v5 R&S,
thanks for your reply
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
VPN over MPLS.
PS:
You might also want to investigate WAAS.  You can obtain LAN like bandwidths, but WANs do not have LAN like latencies.
so does that mean before VPN , it was not possible to connect two offices (two LANs) in two different countries ?
