Showing results forĀ
Search instead forĀ
Did you mean:Ā
What is the difference btw explicit and implicit acknowledgement in OSPF
Deepak Sukumar
Hi Guys,
I have always read that OSPF has two types of LSack . ( Implicit ack and explicit ack ). I would like to know the difference in detail.
Please state the examples where implicit and explicit ack are used and in which scenarios are  they sent .
Deepak
Latchum Naidu
Hi Deepak,
Implicit acks: send the same LSA back.
– Used when you would have sent it anyway.
Explicit acks: OSPF packet type 5.
– Carry only LSA header.
Please rate the helpfull posts.
Naidu.
6 Replies 6
Latchum Naidu
Hi Deepak,
Naidu.
Peter Paluch
Hello Deepak,
Naidu is absolutely correct on this. Just to add an overview how the implicit and explicit ACKs would be used, think of this scenario:
  1. A non-DR router on an Ethernet segment detects a topology change and needs to inform other routers about it. It sends the LSU packet to the DR and BDR using the 224.0.0.6 destination IP address.
  2. Both DR and BDR receive the packet. Normally, you would expect that the DR would send an LSAck acknowledging the successful receipt of the LSU. However, the DR needs to propagate the LSU back to the segment using the 224.0.0.5 destination IP address anyway, so it just does exactly that, without sending a standalone LSAck.
  3. The original router receives the same update from the DR it sent it a moment ago, and it considers it as an implicit acknowledgement. No further LSAck from the DR is expected.
  4. Other routers on the segment receive the LSU and acknowledge its receipt via an explicit LSAck message back to the DR. This is an explicit form of acknowledgement.
Best regards,
Peter
Hi Peter and Naidu,
Thanks for the clarification . My doubt in the 3 rd point is as follows
3.) The original router receives the same update from the DR it sent it a moment ago, and it considers it as an implicit acknowledgement. No further LSAck from the DR is expected.
Question
Does the original router which recieves it own update packet needs to send an explicit ack to DR. To notify DR that it has recieved the update .
Deepak
Hi Deepak,
When even a original routers receives its own update also it sends the implicit ack to the DR.
Naidu.
The example of Peter is very reliable
in case of the LSU which is destined from the DRothers need fast cooked LSACK from the DR/BDR to let the process of Dothers education let faster which is called implicit LSACK .
-When the Dothers received the LSU from DR/BDR this situation will be completed by sending normal LSACK which is called explicit LSACK .
BR
Khaled Kotp
Bryan Middleton
I realise this is a slightly older post now but just came across a couple of sections of the RFC which details the behaviour of acknowledgements pretty clearly: -
13.5.  Sending Link State Acknowledgment packets
        Each newly received LSA must be acknowledged.  This is usually
        done by sending Link State Acknowledgment packets.  However,
        acknowledgments can also be accomplished implicitly by sending
        Link State Update packets
Actions taken on received update LSAs:
          if the received LSA is the same instance as the database
        copy
*        (a) If the LSA is listed in the Link state retransmission list
            for the receiving adjacency, the router itself is expecting
            an acknowledgment for this LSA.  The router should treat the
            received LSA as an acknowledgment by removing the LSA from
            the Link state retransmission list.  This is termed an
            "implied acknowledgment".
This table below is an excellent summary of behaviour with acknowledgements
                                     Action taken in state    Circumstances            Backup                All other states    _________________________________________________________________    LSA  has                 No  acknowledgment    No  acknowledgment    been  flooded back       sent.                 sent.    out receiving  in-    terface  (see Sec-    tion 13, step 5b).    _________________________________________________________________    LSA   is                 Delayed acknowledg-   Delayed       ack-    more  recent  than       ment sent if adver-   nowledgment sent.    database copy, but       tisement   received    was   not  flooded       from    Designated    back out receiving       Router,  otherwise    interface                do nothing    _________________________________________________________________    LSA is a                 Delayed acknowledg-   No  acknowledgment    duplicate, and was       ment sent if adver-   sent.    treated as an  im-       tisement   received    plied  acknowledg-       from    Designated    ment (see  Section       Router,  otherwise    13, step 7a).            do nothing    _________________________________________________________________    LSA is a                 Direct acknowledg-    Direct acknowledg-    duplicate, and was       ment sent.            ment sent.    not treated as  an    implied       ack-    nowledgment.    _________________________________________________________________    LSA's LS                 Direct acknowledg-    Direct acknowledg-    age is equal to          ment sent.            ment sent.    MaxAge, and there is    no current instance    of the LSA    in the link state    database, and none    of router's neighbors    are in states Exchange
