what is the feature of IOS on ISRg2 that automatic create tunnel0 when "show ip int brief"
I got question from my customer that he configure ISRg2, when he try "show ip int brief", he see that router has tunnel0 and use same IP address as Gi0.
#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         10.88.2.1       YES NVRAM  up                    up
GigabitEthernet0/1         10.188.2.1      YES NVRAM  up                    up
Serial0/0/0                172.29.88.88    YES NVRAM  up                    up
Serial0/0/1                unassigned      YES NVRAM  administratively down down
Tunnel0                    10.88.2.1       YES unset  up                    up
He send "show run" that haven't any config about tunnel0. I would like to know what is tunnel0 for? And does it effect to any operate of router or not.
sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(2)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 01:25 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
uptime is 19 hours, 52 minutes
System restarted at 20:37:22 GMT+7 Wed Jan 5 2011
System image file is "flash0:c2900-universalk9-mz.SPA.151-2.T2.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FHK1446737G
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2901/K9
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            None          None          None
data          datak9        Permanent     datak9
6 Replies 6
Yasir Ashfaque
It depends, why dont you share the show running
This is "show run" from my customer. I remove some line about description, username and serial number
Current configuration : 5882 bytes
! Last configuration change at 16:11:42 GMT+7 Thu Jan 6 2011 by jiruttaphol
! NVRAM config last updated at 21:45:39 GMT+7 Wed Jan 5 2011 by jiruttaphol
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname ABC!
boot-start-marker
boot-end-marker
logging buffered 40960
no logging monitor
no aaa new-model
memory-size iomem 10
clock timezone GMT+7 7 0
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
no ip domain lookup
decnet routing 12.288
decnet node-type routing-iv
crypto pki trustpoint TP-self-signed-3985897665
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3985897665
revocation-check none
crypto pki certificate chain TP-self-signed-3985897665
certificate self-signed 01
  3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393835 38393736 3635301E 170D3131 30313035 31333338
  35315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39383538
  39373636 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009A92 0FE6D97D 89B87C67 49EBE78A 1A752AF1 3E40A514 2086D6CF A571CC2A
  4A4E21FD 4FDC495F 9F252B9B D8AD98EB 612E3A49 24C4E2CE 350AFD4C 07A95B17
  54F192FE 261F372D 8A64B630 B1BD9E87 44C14497 72C43526 46803778 1581745E
  1AEEC453 AD5C74C5 CCF8E64C C44F081D B7ACD1EE 0D37B441 AC0F480A 2DDEEDD5
  645B0203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
  551D1104 0B300982 07445055 5F525431 301F0603 551D2304 18301680 14C97B60
  41D4C892 9604D5BD FC7C4D21 D3C6D45A F1301D06 03551D0E 04160414 C97B6041
  D4C89296 04D5BDFC 7C4D21D3 C6D45AF1 300D0609 2A864886 F70D0101 04050003
  81810018 8DA44803 DC0BD861 28EE66AF 3CBFD661 F027AE06 63F318FC 42363BFD
  DEDB8418 207CCD38 2CE07E12 A2ABBF3B 4031B80E 4B6AA922 21DC4501 6CB9806F
  26E89356 96972CB5 7005119B E4D90418 0C50F421 2FB5CC63 4BE71555 35CB8F3C
  C774BCEE BDE71E43 2D918AA4 54B0D706 4223C004 4BCC6D22 ECDFB5AE 4C0F5994 090194
        quit
license udi pid CISCO2901/K9 sn xxxx
redundancy
track 1 interface Serial0/0/0 line-protocol
interface GigabitEthernet0/0
ip address 10.88.2.1 255.255.0.0
no ip redirects
ip pim sparse-dense-mode
ip ospf cost 80
load-interval 30
duplex auto
speed auto
standby use-bia
standby 0 ip 10.88.2.254
standby 0 preempt
standby 0 track 1 decrement 10
interface GigabitEthernet0/1
ip address 10.188.2.1 255.255.0.0
no ip redirects
ip ospf cost 180
duplex auto
speed auto
standby 2 ip 10.188.2.254
standby 2 priority 95
standby 2 preempt
standby 2 track 1 decrement 10
bandwidth 128
ip address 172.29.88.88 255.255.255.0
ip accounting output-packets
ip ospf cost 310
load-interval 30
decnet cost 10
priority-group 10
keepalive 5
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
router ospf 100
network 10.88.0.0 0.0.255.255 area 88
network 10.188.0.0 0.0.255.255 area 88
network 172.29.88.0 0.0.0.255 area 88
no ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip route 172.17.0.0 255.255.0.0 172.29.188.20
ip route 172.17.0.0 255.255.0.0 172.29.88.1 20
ip route 172.19.0.0 255.255.255.0 172.29.88.20
ip route 172.19.0.0 255.255.255.0 172.29.88.1 20
ip route 192.168.223.0 255.255.255.0 172.29.88.20
ip route 192.168.223.0 255.255.255.0 172.29.88.1 20
ip route 192.168.224.0 255.255.255.0 172.29.188.20
ip route 192.168.224.0 255.255.255.0 172.29.88.1 20
ip route 192.168.225.0 255.255.255.0 172.29.188.20
ip route 192.168.225.0 255.255.255.0 172.29.88.1 20
logging esm config
logging 172.16.10.166
priority-list 10 protocol decnet high
priority-list 10 protocol ip high list 191
priority-list 10 protocol ip medium list 192
priority-list 10 protocol ip normal list 193
priority-list 10 default low
snmp-server engineID local 800000092300000B5F430460
snmp-server community XX RO
snmp-server enable traps tty
control-plane
line con 0
logging synchronous
login local
line aux 0
logging synchronous
modem InOut
no exec
transport preferred telnet
transport input all
escape-character NONE
stopbits 1
speed 19200
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
login local
transport input telnet ssh
line vty 5 15
privilege level 15
logging synchronous
login local
scheduler allocate 20000 1000
ntp server 172.16.10.166 prefer
end
I am not sure but this happens when you enable pim multicast. Can you confirm the output of "sh ip pim neighbor" contain this
tunnel0 as an interface
Mahesh
its because IP Multicast Sparse Mode
You can verify it from show int tunnel0
it will show it as  Tunnel protocol/transport PIM/IPv4.
Thank you for your answer, I will check with my customer.
