What is the solution that can route the return traffic through FW2?
goldpartner
                                       default route -->            eBGP           eBGP            <-- default route
Internet---------FW1-------------------R2---------R1---------R5-------------------FW2-----------Internet
           202.100.0.1                                        |                                        |                                        61.100.0.1
           Static NAT                                           |eBGP                               |eBGP                                Static NAT
           for web server                                     |                eBGP               |                                         for web server
        R3--------------------R4
                                                         web server
                                                         192.168.1.1
As showed in the map, between the routers of R1-R5 is eBGP. FW1 and FW2 are stateful firewalls. FW1 advertises a default route to R2 and FW2 advertises a default route to R5 and that is the only route advertised from the firewalls. There is a web server (192.168.1.1) farm connected to R3. There is static NAT on FW1 and FW2 for the web server so some user can access the web server from the internet. For some reason, a user hits the public IP (61.100.1.1) on FW2 to access the web server via the path FW2->R5->R4->R3->webserver. Since the firewalls are stateful firewalls the return traffic has to go via FW2 back to the user. What is the solution to route the traffic through FW2? (No PBR is allowed.)
Giuseppe Larosa
Hello @goldpartner ,
The web server should serve on two different TCP ports , it should be two instances of web server one on port 80 and one on port 8080 for example.
port 80 to be used when accessed from FW1 and port 8080 when accessed from FW2.
static NAT on FW1 and FW2 should be configured taking in account the above.
The R3 router should use PBR to send traffic with source 192.168.1.1 TCP source port 80 to R4 next-hop and traffic with source 192.168.1.1 TCP source port 8080 to next-hop R2.
Edit:
you would like to do this without using PBR ...
use VRFs and you need to use two NICs on the web server one towards VRF FW1 and one towards VRF FW2.
I apologize for the question: but this scenario looks like not feasible are you studying for some certification ?
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Edit:
Hope to help
Giuseppe
Thanks for your solution which I think is a feasible option.
Not studying for some certification but it is only an artificial scenario I discussed with my teammate.
Is it possible that you can provide more details about your second potential solution?
Hello
From R3 perspective, it is mutlihomed with R2/R4 and based on your OP it suggests multipath isnt viable for the two default routes from FW1/2, also based on bgp path selection the FW1 default is being preferred?
If you wish for return path to route via R4/R5/FW2 PBR would be an viable option as it could be also implemented as conditional but you mention this is not possible, can you elaborate as to why?
Kind Regards
Paul
--Correct
--It is only not allowed to see if there is other solution technically.
R3 have two path (two eBGP paths) for default route ?
if Yes then you need to use some eBGP attributes to make path prefer than other.
