what is the use of the config in voice port
sivakondalarao
voice-port 1/0/0
timeouts interdigit 2-----what is the use of this timeout interdigit 2 ?
ankurbhasin
Level 9
Level 9
Hi Friend,
This command is used to specify the number of seconds for which the system waits (after the caller inputs the initial digit) for the caller to input a subsequent digit of the dialed digits. The timeouts interdigit timer is activated when the caller inputs a digit and is restarted each time the caller inputs another digit until the destination address is identified. If the configured timeout value is exceeded before the destination address is identified, the caller is notified through the appropriate tone and the call is terminated.
To disable the timeouts interdigit timer, set the seconds value to 0.
The default value is 10 seconds.
HTH, if yes please rate the post.
Ankur
