OSPF + BGP default route (Prefer OSPF?)
johnelliot
We have a site(Site A) that is connected to one upstream (Only accepting default route via BGP). Site A is also connected via ATM+FE to our "Primary"(Site B) site, and we run OSPF over these two links(Preferring ATM over FE via cost) and redistribute default over the OSPF(default-information originate) - I would like to prefer the defaults provided via OSPF from Site B, over the default received via BGP from Upstream at Site A - I have tried adding a weight to Site A's BGP conf(Eg 1000), but as soon as BGP comes up, the OSPF defaults are ingnored.
pkhatri
Level 11
Level 11
John,
Try adding the following command under your BGP config:
network 0.0.0.0 backdoor
That command has the effect of setting the AD for that route to 200, making it less preferable to the IGP learned route.
Hope that helps - pls do remember to rate posts that help.
Paresh
Sensational Paresh - Worked like a charm!
