what is this log??
anybody know this log means??
John Blakley
It's possibly an IOS bug:
https://supportforums.cisco.com/thread/2240832
Try updating your IOS and see if that helps...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
amabdelh
Can you check the link utilization at the tine of the issue, did you notice overrun counters were incrementing? This could be caused by oversubscription issue
