WHAT IS VIRTUAL ACCESS
adhityakarthik
hi
could you please tell me what is virtual access interface in cisco 2600 router and what is its siginificance
regds
Adhi
Giuseppe Larosa
Hello Adhi,
when you use any form of advanced DDR or virtual DDR that employs a virtual-template or a dialer the virtual-access is a dynamic interface that inherits some charasteristics from the logical interface and uses some physical resources (like B channels on a ISDN PRI or a ethernet or FE when using PPPoE client)
During the PPP session it is the Virtual-Access that gets the IP address in the IPCP negotiation.
When the PPP session terminates the virtual-access is removed as needed.
see the following link
http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_virtual_temp_ifs_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
