What is wrong with this basic prefix-list?
news2010a
Level 3
Level 3
I have a simple configuration:
R1----R3(bgp 100)------------------------------(bgp 200)R4
Then on R4 I would like to see networks 10.177.206.0 and any 10.2.0.0 network advertised.
However, once I applied the prefix-list shown below, I get no such networks.
Routing is working accordingly because if I remove the prefix-list on the redistribute command on R3, I see all networks advertised OK.
R3#show run
Building configuration...
Current configuration : 1462 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface Loopback0
ip address 10.2.255.15 255.255.255.255
ip ospf 1 area 0
interface FastEthernet0/0
ip address 10.2.80.1 255.255.255.0
ip ospf 1 area 0
speed 100
full-duplex
interface FastEthernet0/1
ip address 10.2.60.105 255.255.255.252
ip ospf 1 area 0
speed 100
full-duplex
interface FastEthernet1/0
ip address 10.2.47.200 255.255.255.240
speed 100
full-duplex
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
router ospf 1
router-id 10.2.255.15
log-adjacency-changes
redistribute bgp 100 metric 10 subnets
default-information originate
router bgp 100
no synchronization
bgp log-neighbor-changes
redistribute ospf 1 route-map RM_ENG
neighbor 10.2.47.193 remote-as 200
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
ip prefix-list LIST_ENG seq 5 permit 10.2.0.0/16
ip prefix-list LIST_ENG seq 10 permit 10.177.206.0/24
route-map RM_ENG permit 10
match ip address prefix-list LIST_ENG
set local-preference 200
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R3#
Below is the show ip bgp on R4 if use only "redistribute ospf 1" under the R3 BGP process, without applying the prefix-list.
R4#show ip bgp
BGP table version is 17, local router ID is 4.4.4.4
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 4.4.4.4/32       0.0.0.0                  0         32768 i
*> 10.2.40.0/24     10.2.47.200              2             0 100 ?
*> 10.2.60.104/30   10.2.47.200              0             0 100 ?
*> 10.2.80.0/24     10.2.47.200              0             0 100 ?
*> 10.2.255.15/32   10.2.47.200              0             0 100 ?
*> 10.177.206.1/32  10.2.47.200              2             0 100 ?
R4#
===BELOW IS THE OUTPUT AFTER I APPLY THE PREFIX-LIST as "redistribute ospf 1 . MY INTENTION IS TO SEE 10.2.40.0/24, 10.177.206.0  and other 10.2.0.0 listed but I only see 4.4.4.4
R4#show ip bgp
BGP table version is 22, local router ID is 4.4.4.4
Giuseppe Larosa
Hello Marlon,
with this formulation
your prefix-list matches only the described prefixes. (exact match)
to get what you want you need to use:
ip prefix-list LIST_ENG seq 5 permit 10.2.0.0/16 le 32
ip prefix-list  LIST_ENG seq 10 permit 10.177.206.0/24 le 32
that is the first prefix/len identifies the block, prefix-list allows then to specify a range of prefix lengths for subnets falling within the block
so if you use:
ip prefix-list LIST_ENG seq 5 permit 10.2.0.0/16 ge 25 le 32
ip prefix-list  LIST_ENG seq 10 permit 10.177.206.0/24 le 30
you will see the full potential of prefix-list with this third formulation some ip subnets will be filtered
Hope to help
Giuseppe
Giuseppe Larosa
Hello Marlon,
so if you use:
Hope to help
Giuseppe
Indeed. That worked.
Do you know why the subnet in red below appears as /32?
In reality that is a loopback on R12 that I advertised as /24.  Just curious.
Thank you very much.
Do you know why
   Network          Next Hop
Do you know why
   Network          Next Hop
Marlon
Not entirely sure without seeing configs but if this route is being redistributed from OSPF then OSPF always advertises loopbacks as /32. If you want OSPF to treat it as a /24 then under the loopback interface you need
int loopback 10
ip address x.x.x.x
ip ospf network point-to-point
Jon
Reza Sharifi
Can you remove "set local-preference 200" from the route map and test again?
Reza
