03-03-2025 05:34 AM
Hi, can someone please advise what license should purchase for 8300 router?
requirement: 1. support network advantage features (bgp,qos), 2. support throughput 600Mbps 3. support voice 4 support security feature (vpn)
5. 3 years dna
thanks in advance!
03-03-2025 05:48 AM
M.
03-03-2025 06:02 AM
Thanks @Mark Elsen , one more question, what throughput with license below? the license "Network_Advantage_10M" seems only support 10Mbps throughput, but actually the traffic throughput is 300Mbps+. Can you please advise why? is it because another license "DNA_HSEC" ? Thanks.
03-03-2025 06:26 AM
Hello @Herman2018
please do this command and share output:
#show platform hardware throughput level
03-03-2025 06:41 AM
Thanks sir M02@rt37 for your response! The command "show platform hardware throughput level" is not available. only following command: . The OS version is X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.12.
03-03-2025 07:00 AM
- @Herman2018 : It looks like it ; ref https://www.thenetworkdna.com/2024/03/hseck9-license-for-cisco-c8000v-sdwan.html
Assuming the same applies to your situation,
M.
03-03-2025 05:28 PM
Thanks @Mark Elsen for your advice. What does it mean if the license status is " Not in use"? The didn't purchase the license or not activated yet? or currently not triggered yet? Please advise, thanks
03-03-2025 10:05 PM
Hello @Herman2018
Licence not trigger yet.
03-05-2025 06:57 PM
Thanks M02@rt37 for your advice. The license is not trigger yet. Does it mean we purchased the license, but not activated or the crypto (encryption) traffic volume is still below 250Mbps so not trigger the license? Please advise. The license for 8000 series routers are very complicated. Don't understand why Cisco want to put the license so complicated, don't know how to choose.
03-05-2025 09:59 PM - edited 03-05-2025 09:59 PM
Hello @Herman2018
The crypto traffic volume is still below 250 Mbps, so the router hasn't needed to trigger the HSEC license yet.
Do you have access on you Cisco licensing portals ? You have a lot of details...
03-03-2025 11:27 PM
- Check if this could be applicable to your case too :
https://www.cisco.com/c/en/us/support/docs/routers/xe-sd-wan-routers/218142-configure-hseck9-license-on-cedge-sd-wan.html#toc-hId-1992201669
M.
