What switch configurations are needed to forward traffic?
bobbyBrown1995
Topology:
PC -> Switch -> Network Encryptor (Layer 3 device)
Switch:
  • SVI for PC
  • Default-gateway
    is Network Encryptor
  • Static route 0.0.0.0/0 [1/0] via [Network Encryptor's IP]
  • IP routing is enabled
  • Routed port that connects to Network Encryptor
The switch can ping everything.
The PC can ping its
default-gateway
which is the SVI, and the routed port.
The PC CANNOT ping the Network Encryptor (which is basically a routed port)
There are no ACLs
in network encryptor you must config route toward L3SW for PC subnet.
that it I think no need more config.
