what will happen if router 99% CPU load over extended period
jliow
I know router CPU load reaching 99% is a bad situation.
I would like to know if this situation continues, what will likely happen?
guruprasadr
Level 7
Level 7
Hi, [Pls Rate if HELPS]
Likely situations are:
1. Slow Performance
Services on the Router fails to Respond:
>>Slow Response in Telnet or unable to Telnet
>>Slow Response to Console
>>Slow or No Response to Ping
>>Router doesnot send Routing Updates to other Routers
Pls Rate if HELPS
Best Regards,
Guru Prasad R
