What would be the proper summary address for these?
Delmiro Campelo
Hello support community,
I'm trying to write a summary network address for the ip address in red below, but they need to be separate from the ones in black, is this a proper summary route for these networks in red? 10.20.0.0/10 ?
IP Address Binary 1st octetBinary 2st octetBinary 3rd octetBinary 4th octet
10.0.0.000001010000000000000000000000000
10.2.0.000001010000000100000000000000000
10.3.0.000001010000000110000000000000000
10.20.0.000001010000101000000000000000000
10.30.0.000001010000111100000000000000000
10.31.0.000001010000111110000000000000000
10.32.0.000001010001000000000000000000000
10.40.0.000001010001010000000000000000000
10.41.0.000001010001010010000000000000000
10.44.0.000001010001011000000000000000000
10.45.0.000001010001011010000000000000000
10.48.0.000001010001100000000000000000000
10.50.0.000001010001100100000000000000000
10.51.0.000001010001100110000000000000000
10.52.0.000001010001101000000000000000000
10.53.0.000001010001101010000000000000000
10.55.0.000001010001101110000000000000000
10.56.0.000001010001110000000000000000000
10.61.0.000001010001111010000000000000000
10.63.0.000001010001111110000000000000000
10.70.0.000001010010001100000000000000000
10.71.0.000001010010001110000000000000000
10.72.0.000001010010010000000000000000000
10.73.0.000001010010010010000000000000000
10.74.0.000001010010010100000000000000000
10.75.0.000001010010010110000000000000000
10.76.0.000001010010011000000000000000000
10.77.0.000001010010011010000000000000000
10.78.0.000001010010011100000000000000000
10.79.0.000001010010011110000000000000000
9 Replies 9
rothomas2
What about the subnet mask? Are all this /24?
I think you need to split aggregation in to below three subnets.
10.16.0.0/12
10.32.0.0/11
10.64.0.0/10
10.20.0.0/10 is not a valid prefix.
Please don't forget to rate this post if it has been helpful
-akash
Hi Akash,
correct, but
10.64.0.0/12
would be enough.
Bets regards,
Milan
Hi Milan,
Would 10.64.0.0/12 cover 10.20.0.0? I don't think so, i will cover 10.64.0.0 to 10.79.0.0 if i consider only 2nd octet.
Akash
sorry, I should have been clearer:
10.64.0.0/12 should be enough instead 10.64.0.0/10.
So
10.16.0.0/12
10.32.0.0/11
10.64.0.0/12
is the complete solution.
Best regards,
Milan
Hello
I have it as this:
10.0.0.0/14
10.20.0.0/16
10.30.0.0/15
10.32.0.0/11
10.64.0.0/12
res
Paul
Kind Regards
Paul
Delmiro Campelo
I actually have a totally different result, the ip addresses in black 10.0.0.0, 10.2.0.0, and 10.3.0.0 will be separate from the red ip addresses in red. it would basically be all /12 so I can keep those summary separated. look ok?
IP block 10.0.0.0/12 - range 10.0.0.1 - 10.15.255.254
IP block 10.20.0.0/12 - range 10.16.0.1 - 10.31.255.254
IP block 10.32.0.0/12 - range 10.32.0.1 - 10.47.255.254
IP block 10.48.0.0/12 - range 10.48.0.1 - 10.63.255.254
IP block 10.70.0.0/12 - range 10.64.0.1 - 10.79.255.254
Delmiro
Hello
You original query was to summarise on the subnets you posted , hence the specific summarization.
If you mean to include the other subnets not shown then a more generic addressing would also be applicable.
res
Paul
Kind Regards
Paul
Delmiro Campelo
I ended up using /12 which is a block of 16 subnets for my summary, it accomplished the goal. .
10.0.0.0/12
10.16.0.0/12
10.32.0.0/12
10.48.0.0/12
10.64.0.0/12
Thanks everyone for helping with this.
