When doing factory default, there left log(connection trace)?
Soon Kwan Kwon
Hi all,
During configuring switch, I have question about factory default.
Could you reply to me about the method?
1. The method to check connection trace.
AND
2. When I implement factory default on CISCO switch, there left connection trace?
If not, could you explain how to erase all information?
SK.
Mark Malone
Hi Soon
if you wipe a switch , you will still be left with contents in flash if that's what you mean by connection trace ?
You must go to flash and delete the files manually , especially the vlan.dat file which stays after erase startup reload , everything but the ios version can be removed if you want it completely wiped
dir flash:
delete flash:vlan.dat
Thank you so much Mark.
I understood your reply.
I'll mention more specifically below.
"connection trace"
Did you wnat to check out what people access my company's switch?
That trace is it(connection trace)
Can you understand..? ㅠ
SK.
Ah ok yes  I get you ,absolutely all wiped after a factory reset all counters/traces etc cleared from the switch nothing remains in that sense its wiped completely , the only thing actually left is the flash contents that you have to manually remove , vtp information does remain as well but that's it
Wow perfect answer!
Thank you !!! Mark.
