IP SLA SUPPORT ON Cisco 2600 "Non XM" (2610/2611/2620/2621)
Hello Guys,
Can someone  please confirm that IP SLA tracking feature don't work on Cisco 2600 "Non XM" (2610/2611/2620/2621).
If IP SLA tracking feature don't work on Cisco 2600 "Non XM" (2610/2611/2620/2621)  then what should be my next step
or
If IP SLA tracking feature  work on Cisco 2600 "Non XM" (2610/2611/2620/2621) then on what IOS should router be running.
It should work the closest I can get to on the feature navigator is 2620XM-2621XM
There is no listed specific non-xm model but I cant see that making a difference on the ip sla abilities as its just a feature
5 Replies 5
Mark Malone
Very old router it may not be supported at all , there over 10 years eol
The feature navigator is the tool you use to check what your software or platform can support
ip sla was introduced in ios 11.2 and above so you may still find it on 2600 series
here is the link
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Hello Mark,
Thanks for reply.
I tried to use research feature and then I filter IP SLA features.
I got the some of options in attached file.
Can you please let me know which IP SLA option I should choose for IP SLA tracking and then check which hardware model support it.
Or which IP SLA feature is used for below confgiuration.
ip sla 10
 icmp-echo A.B.C.D source-ip X.Y.Z.S
 frequency 10
ip sla schedule 10 life forever start-time now
track 10 ip sla 10
This image supports all ip sla on 2610XM-2611XM looking at the feature navigator
c2600-advipservicesk9-mz.124-4.T2.bin
Hello Mark,
My router is cisco 2621 NON-XM device.
So IOS c2600-advipservicesk9-mz.124-4.T2.bin will not be able to solve the issue
Am i right ?
