Showing results forĀ
Search instead forĀ
Did you mean:Ā
where is the rating button
alsayed
Hello
where is the rating button  in or to rate the posts in this new forum?
10xs
Giuseppe Larosa
Hello Alsayed,
it is explained in the read me first section
you should be able to see two series of stars on the left bottom:
you can provide a feedback on the post itself using the leftmost or on the links provided using the second series of stars.
be careful because it is a single click move and the leftmost star means 1 the fifth star means 5 and you cannot change your rating once you have clicked.
You need to be logged as in previous netpro forums
Edit:
I see that stars are grey and doesn't allow to rate, probably a temporary failure of the website  sorry for the explanation above that probably you already know
Edit2:
I have been able to rate a post in another thread so it should work of course I cannot rate my own posts.
Hope to help
Giuseppe
