02-19-2017 11:45 PM - edited 03-05-2019 08:03 AM
We are configuring PPPOA on Cisco router and we need enable NAT feafure for inside users to access the internet.
We created ATM sub-interface and VIrtual-template interface, when we enable "ip nat outside" under ATM sub-interface, we observed no any packet hit the ACL which ACL nested in ip nat and the inside users couldn't access the outside network at all, when I configured the "ip nat outside" under virtual-template interface, they could access outside network normally.
Please advise which is the proper interface to enable " ip nat outside"? If there is rule to limit the interface type where the ip nat out side should be configured?
For example, if the command should be configured on an interface whcih interface must have an IP address there ?
02-20-2017 12:17 AM
with PPPoA you typically have a Dialer interface, that is where the 'ip nat outside' command should be configured on.
If you are not sure what to configure, post the router configuration so we can add the necessary bits and pieces...
02-20-2017 12:44 AM
Hello Georg,
I extracted the key configuration from our router as below, if the virtual-template interface is equivalent with dialer interface?
interface ATM0 >>>>>>This is physical ATM interface
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point >>>>>>Sub-infterface
ip unnumbered Loopback10
ip nat outside
ip virtual-reassembly
no snmp trap link-status
pvc 8/35
cbr 2048
tx-ring-limit 2
encapsulation aal5mux ppp Virtual-Template1
max-reserved-bandwidth 100
interface Virtual-Template1
bandwidth 2048
no peer default ip address
ppp multilink
ppp multilink links maximum 1
ppp multilink interleave
ppp multilink endpoint hostname
ppp multilink fragment delay 3
interface Vlan1 >>>>>>>>>>>>>>>> LAN SVI
ip address 10.11.1.2 255.255.255.240
ip access-group 110 in
no ip proxy-arp
ip nat inside
ip nat inside source list 1 interface Loopback0 overload
access-list 1 permit 10.11.1.0 0.0.0.15
When"ip nat outside" enabled on sub-interface, nat didn't work. It works well after I enable "ip nat outside" on virtual-template interface.
02-20-2017 12:53 AM
'ip nat outside' on the virtual template interface is correct. You don't need it on (physical) sub interfaces.
02-20-2017 01:20 AM
Hello Georg,
Thanks a lot for your swift reply, could you please advise where should I find some offical stuffs to prove this configuration is valid ?
We need this to confront customer's challenge.
