where to find a network key on a home router
jlew763
I'm trying to install a wireless printer. It ask me for the network key that should be on the router. i don't see it. How can I find it?
johnd2310
Level 8
Level 8
On your router you create an SSID and assign a key to authenticate to this SSID. On the printer you will need to tell the printer what wireless network to connect to (SSID) and the key to use to authenticate to this SSID. The key is just the password for your home wireless  network
The key is the same you use to connect to your wireless network(SSID) from you home laptop or mobile devices. You will setup your printer to connect to he same wireless network your home computers connect to and the same password your home computers use.
John
**Please rate posts you find helpful**
