whic of these two ios is better for gateway internet router ??
Dr.X
Level 2
Level 2
c7200p-adventerprisek9-mz.124-24.T4.bin
or
disk2:/c7200p-advipservicesk9-mz.124-24.T4.bin
which one is suitable for bgp and internet traffic and qos ???
my router is 7206
regards
These answers can be found by using the feature-navigator:
www.cisco.com/go/fn
On the FN you provide the features you want to use and the system tells you which feature-set you need.
There you would see, that from your two images, the advanced IPservices is enough. But you should go for the T7 as the T4 is quite old.
Leo Laohoo
You want FULL BGP table?
