Which Cisco Router should we use for VoIP Service?
hirmoge123_2
we need to implement VoIP Service and interconnect with exiting fixed line so that Fixed line subscriber can make outgoing calls and receive incoming calls through VoIP, therefore we need to buy Cisco router that can handle 120 calls concurrently and have PRI and Voice capability, and other advanced services, please advice us which router is best to use or give us different routers that are capable to perform this service.
paolo bevilacqua
Recommend a minimum of ans AS5350 for this, you can also use other models for budget reason, but for professional results, AS5xxx is the best choice.
