Which command can show how many routes ASR1K has?
wfqk
Level 5
Level 5
Hi In ASR1K, if we want to count how many routes it has when using command show ip route, we usually need to watch all the output result. But if it has so many routes, it is not easy to see and count all routes. Do we have some command to show the number of all routes? Thank you
try:
show ip route summary
try:
