07-26-2007 11:37 AM - edited 03-03-2019 06:03 PM
Have a client that has a dsl connection. want to get a additional cable connection and have the router split the internet traffic to the cable, and all other to the dsl. what would be the best router/firewall setup?
07-26-2007 11:54 AM
You can go for 800 or 1800 Series router.
If you can get 1700 second hand router that's best choice.
How much users you have?
Dharmesh Purohit
07-26-2007 04:37 PM
Assuming you need 3 Ethernet connections (1 each for DSL, Cable, and Internal network), I think the smallest router that supports that is the 2800 series.
