Which Router to use
icemannz01
Hi All,
I would like to ask for some help in choosing the correct Cisco Router.
The Router's that I need are for a customer that will use 4 of them to create a VPN Link between sites.
All the sites are connected to the internet via VDSL - so the routers would need to support this.
The 4 sites would have about 20 users in each.
What I want to do is connect all the 4 sites together in a VPN Link so that all 4 sites can access each of the other 3 sites.
As I am not that familiar with Cisco Routers I would like some suggestions on the best router to use.
We want to keep the costs down as much as possible but will require a good solid VPN link.
Also any information on the best type of VPN to setup would be appreciated.
ie: we want the vpn to be up all the time and if it fails for some reason then it should automatically reconnect.
Would you use a star topology or a mesh ?
Phil
23 Replies 23
Got it LEO , and can you check the attachment .
Here the wan circuit speed is half duplex or full duplex ?
For example , 35Mbps to 2911 , means when the sum of download and upload is 35Mbps , I would better use 2911 ?
The image looks like it's half duplex but with encryption.
so it is the sum of download and upload , and encryption.
No, the graph is, in my opinion, expressed in FULL ENCRYPTION but in half duplex.
So if you want full encryption and full duplex, half the value expressed in the bar graph.
I attached the document , it is in the last page .
Sorry , I am a little confused .
If My download and upload is both 10M. encryption is also needed .
According to the jpg , which router I should use ...
10 Mbps x 2 (full duplex) x 2 (ecryption) = 40 Mbps.
Worst-case scenario, 890.
Thank you so much , LEO
Glad to be of assistance.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
if my download is 30Mbps, upload is 8Mbps,  and I also want to vpn , so (30+8) * 2 * 2 = 152Mbps.
For bandwidth, you only need to count the it once as it transits the device.  Your aggregate bandwidth being forwarded would just be 38 Mbps, not 152 Mbps.
For sizing a router, VPN imposes some overhead too.  How much depends on exactly what the VPN is doing.  Fragmentation can add much overhead (much of which can be avoided based on configuration and nature of traffic) and actual encryption can add very much overhead, unless the device has encryption hardware (many newer VPN capable routers do).
Router performance is provided as packets-per-second, which is applied to the aggregate of all packets passing through the router.  Why "duplex" is important, when we say we have a 10 Mbps circuit, most can pass 10 Mbps in both directions, so maximum aggregate is 20 Mbps.  However, if there are two such links connecting to a router, assuming the one link's ingress traffic is the other link's egress traffic, you only need to count it once, not twice for forwarding performance.
