No DNS, Cannot ping internet
james.e.squier
HELP! Why do I not have internet access from C1700?
I have 2 routers and two cat switches.
c2911xm is connected to the internet via att dls modem. Internet access works from switch connected from here.
hedge-c2911xm#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            192.168.1.100   YES DHCP   up                    up
Serial0/0                  10.1.1.1        YES NVRAM  up                    up
FastEthernet0/1            192.168.0.1     YES NVRAM  up                    up
C1700 is connected via serial to c2911xm. from host int c1700 side I can ping the default gateway 192.168.1.100 but not the DLS router from the C1700..
C1700-1>sh ip int bri
FastEthernet0/0            192.168.2.1     YES NVRAM  up                    up
Serial0/0                  10.1.1.2        YES NVRAM  up                    up
Serial1/0                  unassigned      YES NVRAM  administratively down down
I have EIGRP running on both routers.
hedge-c2911xm#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.254 to network 0.0.0.0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, Serial0/0
C    192.168.0.0/24 is directly connected, FastEthernet0/1
C    192.168.1.0/24 is directly connected, FastEthernet0/0
D    192.168.2.0/24 [90/2181120] via 10.1.1.2, 06:34:52, Serial0/0
S*   0.0.0.0/0 [254/0] via 192.168.1.254  #DSL Router
Gateway of last resort is not set
D    192.168.0.0/24 [90/2172416] via 10.1.1.1, 06:35:34, Serial0/0
D    192.168.1.0/24 [90/2172416] via 10.1.1.1, 06:35:17, Serial0/0
C    192.168.2.0/24 is directly connected, FastEthernet0/0
James
3 Accepted Solutions
Sindhu_kumar
In Router C2911XM can you redistribute static route into EIGRP so that C1700 router will receive the default route via EIGRP. Then from C1700 router you can access Internet   if natting is configured properly.
In C2911XM Router
router eigrp [as]
redistribute static [metric x x x x x ]
In C1700 Router sh ip route
D*EX 0.0.0.0/0 [170/XXXXXXX] via 10.1.1.1
Edwin Summers
Level 3
Level 3
First item I would confirm is routing.  Does the C1700 have all necessary routes (a route to the "DLS" as well as a default, if needed)?  Also confirm that the cable modem (is this the "DLS" router?) has routes to your internal network.  By default it likely only has a route to the immediate LAN that it serves.  Some will allow other static routes to be configured.
Once this is working you may need to confirm that your cable modem will also perform NAT for networks other than it's immediate LAN network.  If not, you may need to "double NAT" by having your c2911 NAT all internal traffic to it's fa0/0 interface.
Best of luck! -Ed
Hi Did you enable Ip nat inside command on S0/0 interface on Router C2911XM.
6 Replies 6
Sindhu_kumar
In C2911XM Router
router eigrp [as]
Edwin Summers
Level 3
Level 3
Best of luck! -Ed
Sindukumar and Edwin,
It is still not working. Maybe my NAT is wrong
Sindukumar, I did as you sugested and redistributed the static route via EIGRP.
C1700
C1700-1>sh ip rout
Gateway of last resort is 10.1.1.1 to network 0.0.0.0
D    192.168.0.0/24 [90/2172416] via 10.1.1.1, 08:11:21, Serial0/0
D    192.168.1.0/24 [90/2172416] via 10.1.1.1, 08:11:05, Serial0/0
D*EX 0.0.0.0/0 [170/2172416] via 10.1.1.1, 00:00:34, Serial0/0
Edwin,
C2911 is already double NAT'd.
hedge-c2911xm
ip nat pool gbl.net 192.168.1.100 192.168.1.100 netmask 255.255.255.0
ip nat inside source list 7 pool gbl.net overload
access-list 7 permit 192.168.0.0 0.0.0.255
access-list 7 permit 10.1.1.0 0.0.0.255
access-list 7 permit 192.168.2.0 0.0.0.255
interface FastEthernet0/0
ip address dhcp
# This interface is configured to DHCP because the DSL router will not route if is set to static but it will always be 192.168.1.100
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
Any other advice?
James
Sindhukumar and Edwin,
Thanks for the help. It works now.
ATT DSL Router 192.1.1.254 Connected to 192.168.1.100 (hedge-c2911xm fa0/1)
hedge-c2911xm
     fa0/0 192.168.0.1 -> Connected to switch
     fa0/1 192.168.1.100 -> Connected to DSL router
     Serial0/0 10.1.1.1 -> Connected to 10.1.1.2 (C1700-1 serial0/0)
C1700-1
      Serial0/0 10.1.1.2 -> Connected to 10.1.1.1 (hedge-c2911xm serial0/0)
      fa0/0 192.168.2.1 -> Connected to switch
Resolultion:
EIGRP: Redistribute static route
NAT:
interface Serial0/0
ip nat inside
Question? I do not need
access-list 7 permit 192.168.2.0 0.0.0.255?
Iearned a lot.
James
ALIAOF_
Level 6
Level 6
Are you able to post a topology diagram with IP's?
