Why are there 1024 available subnets instead of just 4?
joshgarmon116
My material says this network has 1024 total subnets and 62 hosts per subnet.
172.128.0.0
172.128.64.0
172.128.128.0
172.128.192.0
These are the only "subnets" I see and understand.
Where are the other 1020 coming from?
manish arora
Level 6
Level 6
172.128.0.0 it's a class B address and you are subnetting it from /16 to /26 which means you are using 10 bits from the host address towards subnet, so your total no of subnets = 2 raise to power N ( N is 10 in your care ) so its 1024.
Also the above mentioned subnets that you created in Red are in correct for /26 mask , they should be :
172.128.0.0/26
172.128.0.64/26
172.128.0.128/26
172.128.0.192/26
Each of the above gives you 64 Host and if you continue on the same logic you will get to 1024 subnets. :-)
Manish
More Info :
http://www.cisco.com/c/en/us/support/docs/ip/routing-information-protocol-rip/13788-3.html
