Why do my PING sweeps end !!...... and not !!MMMM over IPSEC VPN?
Paul Morgan
                   Hello Community,
When I test my branch lines for MTU, I get my PING sweeps up to the MTU then the PINGs fail. Why do I not get an MMMM for Could Not Fragment?
Is it something to do with IPSEC or is something not working?
Paul
eg
Packet sent with the DF bit set
6 Replies 6
jamie.grive
Are ICMP unreachables enabled on the interface in question? (show ip int xxxx | inc unreach)
Although if you are testing this from a router which already knows it is going to be a too big MTU on the VPN interface it's not going to send an ICMP unreachable to itself so you would want to test it from another device back in the path (e.g. behind the VPN device)
If I use ping from a Windows box on the LAN it also just times out. Except if the packet size is over the outgoing interface MTU eg 1472.
So a ping of 1474bytes from the LAN gets PACKET NEEDS TO BE FRAGMENTED BUT DF BIT SET, but lower than that just times out, all the way down to when packets are smaller than the MTU ie 1310 from the LAN.
1310 + 28 (IP + ICMP)= 1338 + IP + GRE + IPSEC = 1338 + 20 + 4 + 56 = 1418 which is spot on since the TUNNEL mtu is 1420
But it's that middle area that shows the Timeout that is a problem. On the router, I would expect the Could Not Fragment response?
Makes sense - what version and platform is this?
This result is seen on all my routers. 1841, 1941, 1921, 887. Using either IOS 12.4-24 or 15.1
The network is a hub&spoke setup with all branch spokes connected using IPSEC VPN over GRE tunnels.
So to summarise:
x<1310 = Succeed
13111472 = Timeout
x>1473 = ICMP Unreachable (Packet needs to be fragmented)
Maybe it's something like 'no ip unreachables' on the Tunnel interface? 'show ip int tunnelX' to confirm
Nearly.
X less than or equal 1311 = success
13121472 = Timeout
X>1472 = ICMP Unreachable (Packet needs to be fragmented)
All Tunnels are ICMP Unreachables are always sent.
This is inherited from the interface the Tunnels are built on as far as I know. This is the same at both ends.
