Why does VLAN 10 not reach the default gateway?
ngaoiwnwa2
Hi, I wonder why my client with VLAN 10 can't reach the default gateway. The client is configured with an ip address and a gateway address.
The switch which the client is connected to is configured to VLAN 10 on
 int fa0/1
The switch which is connected to the bottom switch is configured as trunk
  • int fa0/2 -> switchport mode trunk,
  • switchport trunk allowed vlan 1,10,20
same with the bottom switch which is connected to the top one same configuration
int fa0/2 access vlan 20
int fa0/3 configured as trunk
R0 is configured with g0/0/0 no shutdown subinterfaces
  • g0/0/0.10 encapsulation dot1q 10
  • ip address 192.168.10.1
  • g0/0/0.20 encapsulation dot1q 20
  • ip address 192.168.20.1
I can ping the gateway from client in VLAN 20 but I can't from client in VLAN 10. Why is that? I mean the switch should broadcast the frame until it hits the router right?
M02@rt37
Hello @ngaoiwnwa2
On Switch0 add vlan 10 !
configure-terminal
vlan 10
After that PC0 should be able to ping its Gateway:
Best regards
M02@rt37
Hello @ngaoiwnwa2
configure-terminal
vlan 10
Best regards
Ruben Cocheno
@ngaoiwnwa2
 FYI : Community group for Packet Tracer project questions
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
