Why EIGRP is not learning all the routes?
frank
Two routes have EIGRP neighbor established over GRE interface but they are not learning the full routes in its neighbor's table.
Here are the config and show:
<old-denhav1012>
router eigrp 113
redistribute connected route-map deny_connected
network 10.116.129.2 0.0.0.0
network 10.175.211.252 0.0.0.3
distribute-list EIGRP-Tunnel-Out out Tunnel0
no auto-summary
eigrp log-neighbor-changes
old-denhav1012#sh ip eig nei
IP-EIGRP neighbors for process 113
H Address Interface Hold Uptime SRTT RTO Q Seq Type
(sec) (ms) Cnt Num
0 10.175.211.254 Tu0 14 01:02:19 91 5000 0 410
old-denhav1012#
old-denhav1012#sh ip eig top
IP-EIGRP Topology Table for AS(113)/ID(192.168.207.35)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 192.168.207.35/32, 1 successors, FD is 297372416
via 10.175.211.254 (297372416/128256), Tunnel0
P 10.175.211.252/30, 1 successors, FD is 297244416
via Connected, Tunnel0
P 10.116.40.128/28, 1 successors, FD is 28160
via Rconnected (28160/0)
P 10.116.129.2/32, 1 successors, FD is 128256
via Connected, Loopback10
old-denhav1012#
<denhav1012>
router eigrp 113
passive-interface default
no passive-interface Serial2/0:23
no passive-interface Tunnel0
network 192.168.207.35 0.0.0.0
no auto-summary
no eigrp log-neighbor-changes
denhav1012#sh ip eig 113 nei
(sec) (ms) Cnt Num
0 10.175.211.253 Tu0 10 01:06:05 22 5000 0 12624428
1 10.116.64.219 Se2/0:23 14 04:06:28 222 2280 0 151500
denhav1012#
denhav1012#sh ip eigrp 113 top
P 0.0.0.0/0, 1 successors, FD is 30720, tag is 65309
via Redistributed (30720/0)
P 192.168.207.35/32, 1 successors, FD is 128256
via Connected, Loopback0
P 10.116.64.219/32, 0 successors, FD is Inaccessible
via 10.116.64.219 (41356800/128256), Serial2/0:23
denhav1012#
old-denhav1012 only learns one route from denhav1012 but not 0/0 nor 10.116.64.219/32?
Thanks.
6 Replies 6
Giuseppe Larosa
Hello Frank,
10.116.64.219/32 is declared inaccesible and has an infinite metric = max metric.
P 10.116.64.219/32, 0 successors, FD is >> Inaccessible
So this is correct I don't know why it is Inaccessible but for this reason it is not advetised to other router or if it is the route cannot be used
I think the reason can be that a better protocol like eBGP (AD 20) is providing a better route or that you need a network comand for it like:
network 10.116.64.219 0.0.0.0
for the default route you may need a redistribute bgp or static or the usage of the command
ip default network.
There are not enough details to undestand how new router learned the default route
Hope to help
Giuseppe
Giuseppe,
Thanks for the reply, it works after I added the network statement for 10.116.64.219, but I need to use a wilder mask to cover few more sites.
However still don't know why it was "Inaccessible", the prefix is not from any other routing protocol, the only thing it that they are all from ISDN circuits.
The default route was redistributed from BGP into EIGRP on denhav1012, it should send to its neighbor old-denhav1012 but why it doesn't.
If I add "ip default network" then defeats the propose using dynamic routing protocol.
Hello Frank,
router eigrp xx
no auto-summary
you can create a summary route on an interface basis (outbound) using
int type x/y
ip summary-address eigrp xx 10.116.64.0 255.255.255.0
this is an example
about the default route it is a special network and EIGRP has no direct way to indicate 0.0.0.0/0 (it can use some special flags on the network object of default network command)
I'm afraid it is not enough to use redistribute BGP for the default route
may you post the configuration ?
Hope to help
Giuseppe
Hi Giuseppe,
The old-denhav1012 starts to learn the 0/0 from denhav1012 after we reload the old-denhav1012, it is being up for almost 3 years...
Looks like we have all our problem solved, thanks for you help!
yes EIGRP and your comment is helpful for me.
thanks
Education
Enhanced Interior Gateway Routing Protocol is the best way to learning all
Education
