why I am not able to paste Ip access-list containg 10+ lines
MasoodA
I know I had done this many times in the past but I was trying to paste an
access-list
(standard) into a 3800 L3 switch from a notpad file but the device kept rejecting it. I had to insert line by line (about 12 lines).
I had done this on Cisco routers many times with no issues but this switch gave me hard times. could someone please shed light on this so I know why that happened?
Ip access-list 30
a standard Ip access-list.
I prepared it in notepad because i wanted to add three new lines.
No access-list 30
then conf t and pasted new
access-list
but switch kept rejecting until I inserted line by line. it was working as expected after adding line by line as I was seeing IPs getting hits.
Thank you and
best regards,
Masood
18 Replies 18
First I confuse about 10 lines I assume SW reject more than 10 line
Anyway
https://community.cisco.com/t5/switching/
access-list-v-s-ip-access-list/td-p/1905219
There is different between
access-list and ip access list
Ip access list
need to specify standard or extended acl.
Here is the issue
Before as you mention you was success because you was use
access list
Here you use
 ip access-list
without keyword standard and complete all acl is rejected from SW not only two last lines.
MHM
I believe I did not use standard initially. Yes.
Masood
You are so welcome.
Have a nice day
MHM
Hello @MasoodA ,
you have actually created a named standard ACL with name = 30 , when you do this the following lines are in ACL mode and do not need to start with
access-list 30
To create a classic numbered standard acl you use commands like
ip access-list 30 permit host <A>
ip access-list 30 permit host <B>
and so on and in this case all the commands are in global config and you need to have
ip access-list 30
in each line
Hope to help
Giuseppe
