Why Is nat overload necessary?
Iloveyou
What happens if we put ip nat outside and ip nat inside BUT we DONT put
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.1.0   0.0.0.255
From my logical understanding, if you configure NAT on the interfaces, the router should know what to do even if you dont overload the interface. So why is NAT overloading and ACL necessary?
8 Replies 8
first this way of study right way
second
even if you not add overload the router automatically will add it.
for ip nat inside vs ip nat outside
first one NATing the source of packet (go from inside to outside)
second one NATing the destination of packet (go from inside to outside)
I think we have to put the access list and the dynamic overload command before it works?
No put access list, no put dynamic overload command no work?
I think dynamic overload command not automatic put.
I think we have to put the access list and the dynamic overload command before it works? Yes,
even if you not add overload the router automatically will add it. <<- what I meaning that if you config ip nat inside list...... without add overload keyword the router automatically Will add it.
""No put access list, no put dynamic overload command no work?
I think dynamic overload command not automatic put.""
please elaborate more about these two points
I just put ip nat inside and ip nat outside on the interfaces.
The dynamic overload command does not automatically appear.
you can see I config ip nat inside without overload
when I do show run
there is overload
You post have many Q' I hope overload keyword is now clear to you.
Other Q
If you add to interface ip nat inside/outside
But
I DONT config ip nat inside source static/list what happened?
Simply the traffic will flow without any NATing.
But why it no work.
On LAN interface i put ip nat inside
on wan interface i put ip nat outside
I no put acl and i no put "ip nat inside source static/list".
Why NAT will not automatic happen?
Ok' these examples show you why you must add ip nat inside static/list
1- You have one ip nat inside interface
And three ip nat outside
If traffic is receive and need to NATing for which outside it automatically NATing ??
2-
Lan's -sw- router1-router2
Router2 have one inside interface and one outside interface
Router2 through it one inside interface recive traffic from all lan's (different subnet) and need automatically NATing traffic' which one will NATing and which not.
That why cisco router and sure other vendor config same
First config NAT boundary with ip nat inside and ip nat outside
Then config guide for nating with
Ip nat inside source static/list
