Why Management VLAN suddenly changed to default VLAN1?
farhanshariam
The problem is certain vlan management on certain switches will suddenly changed to default vlan. Does this have anything to do with configuration because i am sure that the configuration is quite simple.
Thanks.
Hello
Some switch models  only allow 1 L3 interface per switch
If you try to create an addtional SVI it will delete the previous one
Is this what you are querying?
res
Paul
Kind Regards
Paul
