Why my 857 adv security don't have class-map and policy map command ?
now i wanna use traffic shaping on this
but when i use command class-map it doesn't have please advise me.
my show ver.
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T17, R
ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 24-Jan-12 14:40 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
PlasticWorldRouter uptime is 1 hour, 54 minutes
System returned to ROM by reload at 19:02:11 bangkok Thu Feb 2 2012
System restarted at 19:02:52 bangkok Thu Feb 2 2012
System image file is "flash:c850-advsecurityk9-mz.124-15.T17.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 857 (MPC8272) processor (revision 0x400) with 59392K/6144K bytes of memory
Processor board ID FGL1532223Q
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
Router(config)#c?
call             cdp            clock    cns
config-register  configuration  connect  control-plane
crypto
Router(config)#p?
parameter-map     parser     password  policy-manager
ppp               privilege  process   process-max-time
pseudowire-class
i must use any command before use it.
Hi Siriphan
         Cisco 857 doesn't support full QoS implementation. What you got is as follows:
Weighted Fair Queuing (WFQ)
Policy-based routing (PBR)
Per-VC queuing
Per-VC traffic shaping
       If you want to do MQC on the router. You need to consider Cisco 870 serires or higher models.
Seems you're TH people(as me). Just guess from your name.
HTH,
Thotsaphon
Many thank for your answer
yes i am thai people
and which way to use Qos or traffic shaping on 857
i want to dedicate bandwidth around 256 K for 192.168.0.210 for sip protocol
       First off , you want to dedicate BW for a specific protocol. You can do CBWFQ. But it doesn't support on C857. You might consider to use Cisco 870 series to meet that requirement.
HTH,
Thotsaphon
