why the console screen display like this"Warning: filesystem is not clean"and "%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash contained errors which were auto-corrected."while ASR1002 power on??
lvmeixinccie
all:
    i configured a new ASR1002 router yesterday,i powerd on the ASR1002 to check the device include some SPA moduler,but i found my console screen display like this""Warning: filesystem is not clean"and "%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash contained errors which were auto-corrected."while ASR1002 power on.
    anybody know how to resolve these warning and erroers ?is it format the flash can resolve them?!!
thx.
7 Replies 7
Laurent Aubert
There is nothing to worry about. During a cold unexpected reboot (power off), some files may get corrupted and are repaired during the next reboot. If you use a graceful reboot (via the reload command) instead, those messages should disappear.
Laurent.
u are right,reload the device,the warming and errors are not display,but the warming and errors are still display if u power on next time.
I reload the ASR1002-F router, there is not warning message anymore. But the display led "critical" is still on. Is there a way to get rid this alarm? To say the least it is misleading.
I've got the screen-shot for boot up of this router.
cxdrtrp1#reload
Proceed with reload? [confirm]
Oct 28 10:36:55.271 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: proces
s exit with reload chassis code
System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
Last reset at: Thu Oct 28 00:37:13 UTC 2010
ASR1002-RP1 platform with 4194303 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Located asr1000rp1-advipservicesk9.02.06.02.122-33.XNF2.bin
Image size 256053560 inode num 12, bks cnt 62514 blk size 8*512
Boot image size = 256053560 (0xf431138) bytes
Missing or illegal ip address for variable DEFAULT_GATEWAY
Using midplane macaddr
Missing or illegal ip address for variable IP_ADDRESS
Missing or illegal ip address for variable IP_SUBNET_MASK
Package header rev 0 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
        calculated 7b84920e:3701229d:e8468b35:dd834c12:2c3bc588
        expected   7b84920e:3701229d:e8468b35:dd834c12:2c3bc588
Image validated
PPC/IOS XE loader version: 0.0.3
loaded at:     00800000 0FC33004
zimage at:     00808674 009814DD
initrd at:     00982000 00FB0219
isord at:      00FB1000 0FC31000
avail ram:     00400000 00800000
Kernel load:
Uncompressing image... dst: 00000000 lim: 00400000 start: 00808674 size: 00178E6
9...done.
Now booting the IOS XE kernel
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVIPSERVICESK9-M), Version
12.2(33)XNF2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 07-Jul-10 01:19 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
% NONE-MODE: Redundancy Mode Change - peer will be reloaded when config mode exi
ts
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1002-F (2RU) processor with 1735082K/6147K bytes of memory.
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7798783K bytes of eUSB flash at bootflash:.
Press RETURN to get started!
Hi All,
I have same problem, but in ASR1004. I've reloaded that device, but when i power on again, the notice
%IOSXEBOOT-4-BOOT_SRC: (rp/0): Non-HD Boot
still there.
is anybody can help me??
Thank you.
peter.x.hall
The errors are not serious provided it say 'auto-corrected'.
The documentation says issue a 'reload' command before powering down to ensure all the log files are closed correctly (it's Linux based), but it isn't clear from the documentation at what point it is ready to be powered off.  It appears that when it displays 'initialising hardware' that is the right time, but you could miss that message.
If you issue the command as 'reload pause' and wait for the 'Enter [continue]...' prompt it halts at the right point and means you don't need to have one eye on the terminal while being ready to dive for the power switch!
mi2hkho
I just a similar error messages on ISR-4331 router.  Reloading the router eliminates the messages.
Mimi
I have the same problem rebooting the system after an OS installation
Cisco IOS XE Software, Version 03.18.04.SP.156-2.SP4-ext
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 5 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 6 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 7 contained errors which were auto-corrected.
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 8 contained errors which were auto-corrected.
