why would an enterprise use BGP ?
mohammed hashim
hi all
I understand the BGP routing protocol and how it works, and why ISPs need BGP to exchange routes.
but why would an Enterprise use BGP for their internet access ?
if it all what they need is the internet access, then they can simply forward the traffic to the ISP, and the ISP will take care of the traffic !
thanks,
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Presupposing you only have one Internet connection, you're correct, you shouldn't need to use BGP with your ISP.
However, if you have multiple Interconnections, especially with different ISPs, the BGP with them can be useful.  The most common reason, is to "know" best path to same destination, between ISPs.  But BGP can also be use to dynamically pass policy information.
In fact, dynamic policy information, via the routing protocol, is one reason BGP might be used internally with a (large) Enterprise.
Jeff Van Houten
Level 5
Level 5
For an enterprise with multiple sites, many MPLS providers require the CE routers run BGP to exchange routes with the PE providers so a mesh network can be created.
