why would trunk port go in "err-disabled"? bpduguard isn't configured for this port.
gavin han
why would trunk port go in "err-disabled"? bpduguard isn't configured for this port. following is the port info.
sw#sh run int TenGigabitEthernet3/2
Building configuration...
Current configuration : 203 bytes
interface TenGigabitEthernet3/2
switchport
switchport trunk allowed vlan 35-37, 42, 43
switchport mode trunk
no ip address
end
sw#sh int TenGigabitEthernet3/2
TenGigabitEthernet3/2 is down, line protocol is down (err-disabled)
  Hardware is C6k 10000Mb 802.3, address is b0fa.eb0f.3e84 (bia b0fa.eb0f.3e84)
  Description: UCS
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
Hello Gavin,
Before you go out and start replacing things, please have a log in your buffer. Lets see if you have a log entry still on your device which provides a clue as to why this port went down . (I assume it went down recently)
show log | i TenGigabitEthernet3/2
Have a log if you see anything.
If you dont have a log entry, please go to the affected interface and perform a shut and after a few seconds a no shut to see if the port comes up again.
I assume it will stay up for a short period and then retrun into err-disable state based on your recent statement. In any case, i hope that the    show log | i TenGigabitEthernet3/2
marQes
Markus Schwarz
Hello Gavin,
I have come across this problem a few times in the past. Most of my problems were encountered during install activies as I kept constantly disconnecting and moving the GBICs in and out but of course there are other reasons:
There are various reasons for the interface to go into errdisable. The reason can be:
  • Duplex mismatch
  • Port channel misconfiguration
  • BPDU guard violation
  • UniDirectional Link Detection (UDLD) condition
  • Late-collision detection
  • Link-flap detection
  • Security violation
  • Port Aggregation Protocol (PAgP) flap
  • Layer 2 Tunneling Protocol (L2TP) guard
  • DHCP snooping rate-limit
  • Incorrect GBIC / Small Form-Factor Pluggable (SFP) module or cable
  • Address Resolution Protocol (ARP) inspection
  • Inline power
The most common reason (for me anyhow) was donw to cable and GBIC so I assume this would be the best place to start.
Hope that helps
Regads
marQes
Leo Laohoo
The answer to this question is the command "sh interface status err".
Hello Gavin,
marQes
