I have an older 2621 router with a WIC-1ADSL card installed. When I look at the card, all three lights (CD, LP, OK) are faint. The router is running the newest 12.3(26) IOS software (c2600-i-mz.123-26.bin). When I do a show interfaces command, the ADSL WIC does not appear, only my 2 Fa ports will show up. From my understanding the WIC is supported in 12.3. Could I have a bad WIC?
Here is the output from sh diag
WIC Slot 0:
DSL SAR (ADSL)
Hardware Revision : 2.3
Part Number : 73-4771-09
Board Revision : C0
Deviation Number : 0-0
Fab Version : 05
PCB Serial Number : FOC09154ULV
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : PA-1C-P=
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 2E 41 02 03 82 49 12 A3 09 42 43 30
0x10: 80 00 00 00 00 02 05 C1 8B 46 4F 43 30 39 31 35
0x20: 34 55 4C 56 03 00 81 00 00 00 00 04 00 FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ADSL is only supported in some versions of IOS.
I recently ran into this with a 1841 and ended up using c1841-advsecurityk9-mz.124-15.T1.bin.
I tried the IOS feature tool, but it didn't even show the WIC-1ADSL as a WIC option for the 2621. The WIC spec sheet does say it works with the 2600 series.
Please rate helpful posts.
Dave
