WIC 1ADSL configuration
landrybrou
Hi everybody,
we bought a used Cisco 1841  router with a WIC 1ADSL module and I am asked to configure it so that we can connect to Internet using our ADSL phone line.
Actually, I started via commands with some configurations found on the internet but it is not working.
I wanted to try via SDM interface, but could not launch and I don't know why.
Please anyone who deals with such a configuration or anybody who well knows about that kind of configuration will be very welcome.
Thank you a lot
NB: Informations got from my Broadband operator are:
login: MY_LOGIN
password: MY_PASSWORD
We got our LAN's individual IP address dynamically from our operator using its given setup box.
and the ranges are:
 reserved: 192.168.1.1 to 192.168.1.9
usable: 192.168.1.10 to 192.168.1.100
I hope the above informations will help.
Thank you again.
2 Accepted Solutions
Amit Goyal
Hi Landrybrou,
Please get the below details from your provider.
PVC details (VPI and VCI values)
Is this connection PPPOA or PPPOEOA?
Use below link to configure further.
for PPPOA
http://www.cisco.com/c/en/us/td/docs/routers/access/1800/1801/software/configuration/guide/scg/pppoanat.html#wp1205844
for PPPOEOA
https://supportforums.cisco.com/discussion/11554406/configuring-cisco-1801-router-pppoe#3685750
-Amit
Also please elaborate when you say "it doesn't work".
>Are you not able to get ip address from ISP?
>Internet is not reachable from LAN?
I will wait for the PVC details.
-Amit
7 Replies 7
Amit Goyal
Hi Landrybrou,
for PPPOA
for PPPOEOA
-Amit
I don't really know if it is PPPoEoA but I have already tried PPPoA configuration link you provided.
And it doesn't work.
But my architecture is made of the followings:
- an ADSL line connected to our 1841 router on the WIC 1ADSL port using RJ11 connector
- a router 1841 with 1 ADSL card and with 2 Fast ethernet ports.
- a switch connected to the router trough Fa0/0 port. and LAN PCs are connected to each other and getting access to Internet.
Anyway I will try to get thoses PVC détails from my ISP and let you know then.
Thank you
-Amit
the followings are informations got from my ISP:
Encapsulation:  PPPoE
Multiplexing:  LLC based
VPI = 8
VCI = 35
Login =MY_LOGIN
Password =MY_PASSWORD
IP:  dynamically from ISP
Hope this could help.
Thank you
So this is PPPOEOA. Please use below link to configure your DSL line.
If it doesn't work, capture below information.
ping atm interface atm0 8 35 end-loopback
ping atm interface atm0 8 35 seg
debug ppp negotiation
debug ppp authentication
-Amit
I used the configuration provided by the link but still doesn't work.
Also I can't run these two commands:
            GT_Internet_Router#ping atm interface atm0/0/0 8 35 end-loopback
            Translating "interface"
            % Invalid input detected at '^' marker.
            GT_Internet_Router#ping atm interface atm0 8 35 seg
            Translating "atm"
Below is the capture of "debug" commands
         GT_Internet_Router#debug ppp negotiation
         PPP protocol negotiation debugging is on
         GT_Internet_Router#debug ppp authentication
         PPP authentication debugging is on
Please find below the running configuration:
GT_Internet_Router#sh run
Building configuration...
Current configuration : 1646 bytes
version 12.3
hostname GT_Internet_Router
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXX
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.9
ip dhcp pool LAN
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   domain-name wr
ip ips po max-events 100
no ip domain lookup
no ftp-server write-enable
no crypto isakmp ccm
interface FastEthernet0/0
no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet0/1
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface ATM0/0/0
 no ip address
 shutdown
 no atm ilmi-keepalive
 dsl operating-mode auto
 pvc 8/32
  pppoe-client dial-pool-number 1
interface Dialer0
 ip address negotiated
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 ppp chap hostname MY_LOGIN
 ppp chap password 0 MY_PASSWORD
 ppp pap sent-username MY_LOGIN password 0 MY_PASSWORD
 ppp ipcp dns request accept
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
ip nat inside source list NAT interface Dialer0 overload
ip access-list standard NAT
 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
 password xxxxxxxxx
 login
line aux 0
line vty 0 4
 password xxxxxxxxx
 login
end
Note: I can't set "vlan interface" on my router
       GT_Internet_Router(config)#interface vlan 1
so I configured Fa0/1 instead of Vlan 1 for Telnet purpose.
Is there any problem ??
Also I want you to check the atm interface
GT_Internet_Router#sh interface atm0/0/0
ATM0/0/0 is administratively down, line protocol is down
  Hardware is DSLSAR (with Alcatel ADSL Module)
  MTU 4470 bytes, sub MTU 4470, BW 800 Kbit, DLY 640 usec,
     reliability 0/255, txload 1/255, rxload 1/255
  Encapsulation ATM, loopback not set
  Encapsulation(s): AAL5  AAL2, PVC mode
  23 maximum active VCs, 256 VCs per VP, 0 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output never, output hang never
  Queueing strategy: Per VC Queueing
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
PS: I attached the sample of my network diagram
First you bring the ATM interface up.
ATM0/0/0 is administratively down, line protocol is down<<<<<
Go to interface ATM0/0/0 and apply "no shut"
Status should be as per below then only you can move further
ATM0/0/0 is up, line protocol is up
use below commands to ping via PVC
ping atm interface atm0/0/0 8 35 seg
-Amit
