11-12-2005 04:27 PM - edited 03-03-2019 10:57 AM
I am installing the WIC-1DSU-T1 V2 in a 1720 router and it is not showing up (no lights, no mention in sh ver or sh int). I am pretty sure the card is good, I tried dropping it in a 2821 we have and it looks fine. I also tried swtiching slots on the 1720 to no avial. According to Cisco this config is valid (see below).
Anything special I need to do to use this card in this router?
Config:
1720 Router
IOS 12.1 (12.1 27b)
Slot 0 WIC-1DSU-T1
Slot 1 WIC-1DSU-T1 V2
Solved! Go to Solution.
11-12-2005 05:33 PM
I think its your IOS version. for the v2 wics, if I remember right, you need a 12.2 IOS. Try upgrading your IOS and that should help.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00801a9184.html
----Edited-----
I ran a software advisor check and it lists a 12.3 or 12.2 IOS (min of 12.2.15ZL1) to support your v2 version of wic. (IP Only feature set).
11-12-2005 05:33 PM
----Edited-----
