WIC-1T replacement for 4331
carl_townshend
Hi All
We currently have a WIC-1T serial interface in our old router with DB60 cable, this is running at 1.544Mbit so I am guessing it is a T1, we want to replace with a 4331, however this interface is not supported.
It is for data only, for this do we need a NIM-1T card?
Many thanks
Carl
Hi There
This does not have the X21 serial interface though it has the RJ48 type ? we need the X21 connection
I don't think you can get the X.21 interface as native, you need a converter such as the one below:
https://www.metrodata.co.uk/products/Carrier-Ethernet-Service-Delivery/wc-serial-ethernet-converter-to-serial-x21-v35-eia530.htm
