04-03-2005 07:14 PM - edited 03-03-2019 09:11 AM
Has anyone tried running a WIC-2T in a 2651XM with no NM at 6/6.144Mbps?
Mine will not synchronise with the Telco "feed", however 8.192Mbps will "synch" allbeit "having trouble" managing the transfers.
04-03-2005 11:19 PM
The speed you want to use may not be supported. I am not 100% certain that this is wrong but appearently you are working on the edge of what is possible. Found the following URL about WIC-2T:
Please look under features to see if the additional info matches your situation.
Leo
04-04-2005 12:20 AM
Hi Leo,
thanks for your response,yes I had already seen and read the page in question.
It appears 4Mbps and 8 Mbps are supported but 6Mbps is not, and therein appears a pattern...
Cheers
04-04-2005 01:31 AM
I find it not very clear either. As I read it, 8Mb is only supported on a 2691 under the stated conditions, 4Mb max on other models, appearently including XM routers. That is, APPEARENTLY.
If I find anything more specific, I will let you know.
Leo
