WIC-2T to FASTETHERNET
demonicwall
hello
how are you guys
i new here so i want some help over here
i have two cisco router 1751 with WIC-2t
and also i have ethernet to E1converter (Patton 2701 /I)
and E1 to V.35 converter (Patton 2701C)
i want to connect the fast ethernet in the first router to  WIC-2T in the second router
the thing is i can only carry the data over E1 so i user this converters the main company
Patton support this kind of connection but the problem there is no connection bettween the two
interfaces
the configuration is on the router with the WIC-2T
serial 0
ip add  192.168.0.1 255.255.255.0
encap ppp
the other router
Fastethernet 0
ip add 192.168.0.2 255.255.255.0
so can any body help me with my problem or can help me
with the configuration
thanks alot
paolo bevilacqua
Please review your salutation above ?
Only use routers with E1.
Trying to differently will only cause you problems and bad performances.
soooooooooooooooooooooooooorrrrrrrrrrrrrrrrrrrrrry
im realy sorry
but im new to english so please accept my apologie
i iknow it will cause problem but can you help me with this
i must do it ?
Use the Edit button and make any correction necessary.
