WIC Configuration help
bpierce
I have two locations 1 Seattle 1 Houston,
Houston Router 3725
Seattle Router 3825
I have the FastEhternet 0/0 configured with an ip of 10.100.X.254 mask 255.255.0.0
the Serial0/0 Configured with IP 10.101.X.254 mask 255.255.255.0
I get an error someting to the affect %X.X.X.X overlaps the fastethernet port
when I hit enter.
Ideas
6 Replies 6
Hieu Cao
Level 4
Level 4
Can you try this:
Fastethernet: 192.168.1.254 mask 255.255.255.0
Serial: 10.100.1.254 mask 255.255.255.252
chris_tan
I assume you use 10.100.1.254 mask 255.255.0.0 for your FE. So the total available subnet you can use is 10.100.0.1 - 10.100.255.254. This is a huge subnet, I would suggest you lower down it to 255.255.255.0 if you do not require that big subnet.
As for the Serial, I assume you are using 10.101.1.254/255.255.255.0
FYI, most point-to-point link just require not more than 2 host, so please use 10.101.1.254/255.255.255.252. (other available IP is 10.101.1.253). It just my opinion.. you can still use 255.255.255.0 if you want. :-)
Note: there is a good online subnet calculator you can use --> http://www.subnet-calculator.com/
Hope it help.
Thanks.
Chris -
thaks for the help. no love yet I am going to include both run configs
Thanks for any help you can provide
Housotn:
Building configuration...
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname X
boot-start-marker
boot-end-marker
ip cef
ip domain name X.com
ip audit po max-events 100
interface FastEthernet0/0
ip address 10.100.1.254 255.255.0.0
duplex auto
speed auto
interface Serial0/1
ip address 10.101.X.254 255.255.255.252
ip access-group 100 in
ip access-group 100 out
encapsulation ppp
service-module t1 clock source internal
ip http server
ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1
ip route 10.10.0.0 255.255.255.0 Serial0/1
access-list 100 permit tcp any any log
access-list 100 permit udp any any log
access-list 100 permit icmp any any
access-list 100 permit ip any any
end
Seattle
Current configuration : 2306 bytes
version 12.4
hostname X
logging buffered 51200 warnings
enable secret 5 $1$oQKz$UT.TBMuajHknOST36UcgO.
interface GigabitEthernet0/0
ip address 10.10.X.10 255.255.255.0
duplex auto
speed auto
media-type rj45
negotiation auto
no mop enabled
interface Serial0/0/0
ip address 10.101.X.253 255.255.255.252
encapsulation ppp
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip http server
ip http authentication local
dialer-list 1 protocol ip permit
end
IDEAS?
bpierce
real quick something else i discovered when i do a traceroute on the seattle location it tried to go out my other (working) T1
1) Housotn router config.
- why access-list 100 implement in s0/1 since the acl is allow all? Are you trying to see the traffic flow ?
- you do not need "ip route 10.10.0.0 255.255.255.0 Serial0/1" because the default route will take care of it
What do you mean "you discovered traceroute on other (working) T1" ? Does it mean in seattle router have others WAN link?
Rgds,
Christopher
