WIC port Doesn't Accept IP interface assigning
Ammar
I'm trying a new Fa Port to my router using HWIC-4ESW, for Example the new port is Fa0/1/0, whenever i try to assign in ip to that interface using the command =>
Router(config)# interface fa0/1/0
Router(config-if)# ip address 50.0.0.1 255.0.0.0
i get this error message :
% Invalid input detected at '^' marker.
M02@rt37
Hello @Ammar
HWIC-4ESW is strictly a L2 module, meaning it only supports SVI-based L3 connectivity.
So, if the goal is to assign an IP address directly to an interface, the HWIC-4ESW won't support "no switchport" command.
Since HWIC-4ESW ports act as switchports, you must create a VLAN interface and assign the ip address like that:
Router(config)# interface Vlan1
Router(config-if)# no shutdown
Router(config-if)# switchport mode access
Router(config-if)# switchport access vlan 1
-- on the other side, other module liek HWIC-2FE are routed interfaces.
Best regards
Mark Elsen
 - You may need the "no switchport" command first ,which changes the port from being a Layer 2 interface to a layer 3 interface.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
M02@rt37
Hello @Ammar
Best regards
Thanks a lot my Dear, this was so Helpful . i Found that router 2811suppoerts 2FE2W which i can assign an ip to it's Interfaces , But what Router Model in Packet Tracer Supports HWIC-2FE Because i didn't find it.
Might not be there at all, as PT doesn't simulate all hardware, and the hardware it does simulate, may be missing features.
