will this image fit and function within this router
lcaruso
Level 6
Level 6
I  have an old 1841 currently in a lab setup currenlty running 12.4, but I need to  know without disrupting that setup if this router will (a) run 15.1 and  (b) have any memory left over to actually handle dynamic processes. If  you could enlighen me, I'd really appreciate it.
The new image is c1841-adventerprisek9-mz.151-3.T.bin, 45,265 KB
PUBWORKS#sh version
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 12.4(4)T5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 11-Oct-06 22:41 by kellythw
ROM: System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
PUBWORKS uptime is 2 hours, 43 minutes
System image file is "flash:c1841-adventerprisek9-mz.124-4.T5.bin"
Cisco 1841 (revision 7.0) with 120832K/10240K bytes of memory.
Processor board ID FTX1231Y02Z
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
PUBWORKS#sh flash
-#- --length-- -----date/time------ path
1     29689528 Feb 1 2011 18:22:44 -05:00 c1841-adventerprisek9-mz.124-4.T5.bin
2         4056 Feb 2 2011 09:08:02 -05:00 savedconfig
2236416 bytes available (29696000 bytes used)
2 Accepted Solutions
Leo Laohoo
Don't think 15.X will fit with only 128 mb of DRAM.
I am afraid the image won't be able to run in your router. You have currently 128MB RAM and 256MB FLASH. According to the Cisco Feature Navigator tool at http://cisco.com/go/fn , the image you have referenced requires at least 192MB RAM. It would not even start in your router.
I am sorry to disappoint you.
Best regards,
Peter
8 Replies 8
lcaruso
Level 6
Level 6
the new image is c1841-adventerprisek9-mz.151-3.T.bin, 45,265 KB
Best regards,
Peter
thanks for making that as painless as possible.
You are welcome. Let me just correct myself - you have 32MB FLASH, not 256MB (I wasn't looking quite properly - sorry about that). However, enlarging the CF is not such a problem - any common CF card under 1GB should run fine. Enlarging the DRAM may be a little more complicated.
Best regards,
Peter
Peter, thank you for the handy link to the feature navigator!
Leo Laohoo
I appreciate your assistance. Fast responses!
Thanks for the ratings.
