WIN7 USB driver for console session
JOHN APONTE
I am having no success locating win7 driver for USB console session for newer  3850/2960 lan switches.  Where can I find the driver?  Thanks!!
7 Replies 7
John Blakley
John,
The switch doesn't use a driver. That would depend on what your usb-serial adapter maker is. You would need to look on the adapter that you're connecting to your computer and find a manufacturer model number and go to them to get the driver. Once you find that, you'll be able to connect to the switch.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Thanks for the info...my apologies for not being clear on my intial post...but what I need is where can I download Cisco usb console driver for WIN7 64 ?
John,
There's no such thing. As originally stated, the usb console driver is for your adapter that you're using. It doesn't have anything to do with Cisco equipment.
HTH,
John
John B- I believe what John A is referrring to is the virtual COM port installation.
John A - I'm pretty sure this is what you're looking for.
http://software.cisco.com/download/release.html?mdfid=284455433&softwareid=282855122&release=3.1&relind=AVAILABLE&rellifecycle=&reltype=latest
Ooooohhh...this is used in place of the rollover cables for console access? I haven't used this yet, but I'm definitely going to try it on one of our 2960s I had to look it up after your post Collin; I didn't know that existed. I guess I'm still a little old school +5
HTH,
John
A 10' USB cable will change your life!
Thanks for the info...I will give it a shot and advise.
