Windows 7 cannot obtain an IP address from 4503 Core Switch
Dear all ,,
there is a  Strange issue that  i want to  discuss ,, we have Core-Siwtch 4503 in the main building which is connected to another Core 4503-E in another building ,, now our PCs connected to the 4503-E ,,, any XP M/C can  pick an Dhcp-ip but and M/C run Win.7 Cannot !!!!!!!
action taken :
1st we try to connect our win 7 pc in the node which was connected to xp M/C ,, and it didnot take ip from the DHCP . ,, 2
2nd we ensure from the core-switch configuration and its normal with no mistake
3rd trying to use tool from Microsoft Fix-it Center whih name is ( Microsoftfixit 50475 ) which is just .msi file but the problem face us is that this tool donnot accept to run on win 7 cause its made for vista .
4th after some researchs we notic that there is some modifications have to be performed on registery by disabling the dhcp broadcast flag we did it but nothing change yet
5th now we are waiting to perform another action which is Disable the IP Helper service in win 7
Best regards
Ossamy
6 Replies 6
darren.g
Level 5
Level 5
Mohammed Ossamy Mohammed wrote:
Dear all ,,
action taken :
Best regards
Ossamy
Are you using the 4503 as the DHCP server?
Can you post the DHCP server configuration you're using if you are?
Cheers.
yes am using 4503 as the DHCP and i ll post  the configuration to you tomorrow
hi darren ,,
i attached to  you the configuration of the dhcp server
thanks for your interest
Best Regards
Ossamy
hi darren ,,
Best Regards
Ossamy
Well, your configuration shows you avoiding the most usual problem with configuring a DHCP server on a Cisco device and Windows 7/Vista - if you add a subnet mask in your "default router" statement it almost alwaysd breaks - but you don't have that in your configuration, so we can rule that out.
Are you 100% certain that your attempt to disable the broadcast flag on the Windows 7 boxes worked? This blog post has a great deal of detail which may help.
http://blogs.technet.com/b/teamdhcp/archive/2009/02/12/dhcp-broadcast-flag-handling-in-windows-7.aspx
If that doesn't help then I'm scratching my head. I just had a look at the DHCP configured on my router, which works fine for both XP and Windows 7 (32 & 64 bit) and I can't see much different from yours (apart from the obvious address ranges etc).
Sorry I can't offer more.
Cheers.
Core 4503 #sh run
Building configuration...
Current configuration : 11191 bytes
version 12.2
no service pad
service timestamps debug datetime
service timestamps log datetime
service password-encryption
service compress-config
service sequence-numbers
hostname Pachin-Core
boot-start-marker
boot-end-marker
logging buffered 40960 debugging
username cisco privilege 15 secret 5 $1$snRG$Ko4rfi.T5lJ.QUXS7gRHm/
no aaa new-model
ip subnet-zero
no ip domain-lookup
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 10.1.2.1 10.1.2.10
ip dhcp excluded-address 10.3.1.1 10.3.1.10
ip dhcp excluded-address 10.3.2.1 10.3.2.10
ip dhcp excluded-address 10.4.1.1 10.4.1.10
ip dhcp excluded-address 10.5.1.1 10.5.1.10
ip dhcp excluded-address 10.5.2.1 10.5.2.10
ip dhcp excluded-address 10.5.3.1 10.5.3.10
ip dhcp excluded-address 10.5.4.1 10.5.4.10
ip dhcp excluded-address 10.6.1.1 10.6.1.10
ip dhcp excluded-address 10.1.110.1 10.1.110.10
ip dhcp excluded-address 10.1.3.1 10.1.3.10
ip dhcp excluded-address 10.2.1.1 10.2.1.10
ip dhcp excluded-address 192.168.222.60 192.168.222.80
ip dhcp pool Purchasing
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
dns-server 192.168.0.29
lease 365
ip dhcp pool Finance
network 10.1.2.0 255.255.255.0
default-router 10.1.2.1
lease 365
ip dhcp pool Sales
network 10.2.1.0 255.255.255.0
default-router 10.2.1.1
lease 365
ip dhcp pool Planning
network 10.3.1.0 255.255.255.0
default-router 10.3.1.1
lease 365
ip dhcp pool IT
network 10.3.2.0 255.255.255.0
default-router 10.3.2.1
lease 365
ip dhcp pool Labs
network 10.4.1.0 255.255.255.0
default-router 10.4.1.1
lease 365
ip dhcp pool Marketing
network 10.5.2.0 255.255.255.0
default-router 10.5.2.1
lease 365
ip dhcp pool HR
network 10.5.3.0 255.255.255.0
default-router 10.5.3.1
lease 365
ip dhcp pool INK
network 10.6.1.0 255.255.255.0
default-router 10.6.1.1
lease 365
ip dhcp pool Visitor
network 10.1.110.0 255.255.255.0
default-router 10.1.110.1
lease 365
ip dhcp pool Management-Affairs
network 10.1.3.0 255.255.255.0
lease 365
ip dhcp pool Tech-Affairs
network 10.5.1.0 255.255.255.0
default-router 10.5.1.1
lease 365
ip dhcp pool CEO-Office
network 10.5.4.0 255.255.255.0
default-router 10.5.4.1
lease 365
ip dhcp pool camera
network 192.168.222.0 255.255.255.0
default-router 192.168.222.254
lease 365
ip dhcp pool test
no file verify auto
spanning-tree mode pvst
spanning-tree vlan 2-20 priority 0
port-channel load-balance dst-mac
power redundancy-mode redundant
vlan internal allocation policy ascending
interface Port-channel1
description ** Ether-Channel Downlink To Sales **
switchport
switchport mode trunk
interface Port-channel2
description ** Ether-Channel Downlink To Managment **
switchport
interface Port-channel3
description ***Tech-Affiars UP***
switchport
interface Port-channel4
description ***TO TechAffairs Down***
switchport
interface Port-channel5
description ***TO Labs***
switchport
interface Port-channel6
description ***TO INK***
switchport
interface Port-channel7
switchport
interface Port-channel8
switchport
interface GigabitEthernet1/1
switchport access vlan 150
switchport mode access
interface GigabitEthernet1/2
switchport access vlan 33
duplex full
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
switchport access vlan 200
interface GigabitEthernet1/11
interface GigabitEthernet1/12
interface GigabitEthernet1/13
channel-group 3 mode desirable
interface GigabitEthernet1/14
channel-group 5 mode desirable
interface GigabitEthernet1/15
interface GigabitEthernet1/16
channel-group 4 mode desirable
interface GigabitEthernet1/17
interface GigabitEthernet1/18
interface GigabitEthernet1/19
interface GigabitEthernet1/20
interface GigabitEthernet2/1
channel-group 2 mode desirable
interface GigabitEthernet2/2
interface GigabitEthernet2/3
channel-group 7 mode desirable
interface GigabitEthernet2/4
channel-group 1 mode desirable
interface GigabitEthernet2/5
interface GigabitEthernet2/6
channel-group 8 mode desirable
interface GigabitEthernet3/1
channel-group 6 mode desirable
interface GigabitEthernet3/2
interface GigabitEthernet3/3
interface GigabitEthernet3/4
interface GigabitEthernet3/5
interface GigabitEthernet3/6
interface Vlan1
no ip address
interface Vlan11
description ** Purchasing **
ip address 10.1.1.1 255.255.255.0
shutdown
interface Vlan12
description ** Finance **
ip address 10.1.2.1 255.255.255.0
loopback
interface Vlan13
description ** Management Affairs **
ip address 10.1.3.1 255.255.255.0
shutdown
interface Vlan21
description ** Sales **
ip address 10.2.1.1 255.255.255.0
interface Vlan31
description ** Planning **
ip address 10.3.1.1 255.255.255.0
shutdown
interface Vlan32
description ** IT **
ip address 10.3.2.1 255.255.255.0
interface Vlan33
description ** Servers **
ip address 192.168.0.10 255.255.255.0
interface Vlan41
description ** Labs **
ip address 10.4.1.1 255.255.255.0
interface Vlan51
description ** Tech Affairs **
ip address 10.5.1.1 255.255.255.0
interface Vlan52
description ** Marketing **
ip address 10.5.2.1 255.255.255.0
interface Vlan53
description ** HR **
ip address 10.5.3.1 255.255.255.0
shutdown
interface Vlan54
description ** CEO Office **
ip address 10.5.4.1 255.255.255.0
interface Vlan61
description ** INK **
ip address 10.6.1.1 255.255.255.0
interface Vlan70
ip address 192.168.222.254 255.255.255.0
interface Vlan100
description ** Network Devices **
ip address 10.100.150.1 255.255.255.0
interface Vlan110
description ** Visitor **
ip address 10.1.110.1 255.255.255.0
ip access-group GUEST in
interface Vlan120
description ** Printer **
ip address 10.1.120.1 255.255.255.0
shutdown
interface Vlan150
description ASA VLAN
ip address 10.100.100.1 255.255.255.0
interface Vlan200
description BlueCoat LAN/VLAN
ip address 10.100.200.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.100.100.2
ip http server
ip access-list extended GUEST
permit ip 10.1.110.0 0.0.0.255 host 192.168.0.29
permit ip 10.1.110.0 0.0.0.255 host 192.168.0.33
permit ip any any
logging trap notifications
logging 192.168.0.1
snmp-server community Pachin RW
snmp-server host 192.168.0.1 version 2c Pachin
banner motd ^C
# *** Pachin Group *** #
# WARNING! You have accessed a computer managed by Pachin #
# Group. You are required to have authorization from #
# Pachin Group before you proceed and you are strictly #
# limited to the Use set out within that authorization. #
# Unauthorized access to or misuse of this system or the data #
# contained on this system is strictly prohibited and is likely #
# to constitute an offence under the relevant legislation. #
# If you disclose any data or other information obtained #
# through this system without authority,Pachin Group #
# will take Legal Action against you. #
# You may proceed only if you are authorized to use this #
# Computer as detailed above. #
^C
line con 0
logging synchronous
login local
stopbits 1
line vty 0 4
login local
line vty 5 15
login local
audit
end
Ok there are [potentially] two issues (one MUCH easier to solve than the other) - let's start with the easy one:
What ever port your Win7 box is plugged into, do this:
ADD:
switcport access vlan xxx
REMOVE:
(any other commands)
This SHOULD fix the problem.... Here's the reason why:
You are encapsulating most of your ports with Dot1q tagging, however (assuming here) you're Windows 7 network settings are not specifically sending tags/associating with any VLAN - **MEANING** you're on VLAN1, which has no ip address and no DHCP...
If you're really hell-bent to keep your ports as dot1q, you'll need to add the following command to specifically tell your switch that *IF* there are untagged packets, to send them to a specific VLAN other than 1.
switchport trunk native vlan xxx
Let me know if this work.... (it should)
Sean
http://www.sleepyshark.com/about/sean-brown-professional-biography/
