Wireless LAN Controller Issues
Michael Maxwell
I have a Cisco vWLC, I have a Public SSID which is working on one of my site but on another site when users try to connect it sits in a state of DHCP_REQD rather than RUN.
Does anyone know of any other issues like this with a possible fix. I am using a server as my DHCP not the vWLC, I know this is working fine because one of my sites are getting DHCP. Could this issue be something to do with the AP Groups.
johnlloyd_13
Level 9
Level 9
hi,
i suggest moving this post on the 'wireless' forum section to get more replies.
maybe the fast SSID change is disabled.
enable this feature by going to Controller > Fast SSID Change > Enabled > Apply > Save
or in CLI config network fast-ssid-change enable
Thanks John, we managed to get this sorted. The inteface for the AP was set as management and not the one we configured. All working now.
Thanks for posting back to the forum and letting us know that you have managed to sort it out. Your description of what turned out to be the problem may be helpful to other readers In the forum who might face a similar problem.
Rick
Rick
