wireless Lan controller not access by GUI interface
Arup Dutta
Hi All,
         i have one new cisco WLC 2106.i am not able access it by GUI interface.please help me how can i access it.It is true i am totally new for cisco wlc.
8 Replies 8
Leo Laohoo
If you are new you can start by reading this ...
Cisco Wireless LAN Controller Configuration Guide, Release 6.0
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/Controller60CG.html
Hi Leo,
thank you for your quick reply but i had done each and every thing and
after that i am not able to access it.already i had configure like that
which is mention below.
(Cisco Controller) >show interface detailed management
Interface Name................................... management
MAC Address...................................... 00:1b:d5:cf:c5:40
IP Address....................................... 10.0.0.254
IP Netmask....................................... 255.0.0.0
IP Gateway....................................... 10.0.0.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Physical Port.................................... 2
Primary DHCP Server.............................. 10.0.0.100
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
please help me.
On Fri, Feb 12, 2010 at 2:24 PM, leolaohoo <
Can you ping the Management IP Address?
Is HTTP enabled (by default HTTP is disabled but HTTPS is enabled)?
Have you tried HTTPS?
Hi Leo,
i am able to ping this management ip 10.0.0.254 by console but not
my system and i tried both http:
ip and https:
System(Laptop) ip is 10.0.0.222 gateway 10.0.0.254 and also tried none.
On Fri, Feb 12, 2010 at 2:35 PM, leolaohoo <
Right, well I believe the link between the WLC and the switch should be a dot1q Trunk.
hi,
my setup just like that,
WLC IS CONNECT MY SYSTEM BY A rj45 CABLE.
please tell network scenario so that i can access it by GUI interface.
On Fri, Feb 12, 2010 at 2:46 PM, leolaohoo <
Which port of the 2106 is your laptop connected to?
What is the subnet mask of your laptop?
Disable firewall on the client.
hi,
port 2 is connected on my system.
subnet is 255.0.0.0
system firewall is disable
waiting for your response
On Fri, Feb 12, 2010 at 2:59 PM, leolaohoo <
